Zum Hauptinhalt wechseln
An industrial gas-powered stove by Vulcan.
The commercial stove oven does not stay hot
The Vulcan Gas Stove at work does not stay hot. We are not sure what is causing the stove to not retain heat.
Ist dies eine gute Frage?
Bewertung 1
3 Kommentare
No answer? How about a more descriptive question?
von
Comes on for 12 minutes goes out pilot light and all
von
Manon First see it is using an igniter or a pilot light.
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Sounds like a gas pressure issue, make sure the gas lines are not bound or pinched.
The pilot light should not be off or too low, and should be carefully adjusted to have a low burn to ignite the main burners.
When the main burners are on and suddenly go out, it could be an indication of poor flow of either too much gas or too much air, because air is required for the flames to flaming. A quick through cleaning of the burners should do the trick.
Hope that helps
-SF
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Willymae Smith-McNeal wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 26
Insgesamt: 379
