Zum Hauptinhalt wechseln
The HP Pavilion g6-1b79dx is a 15.6” laptop with a pewter finish made in 2011. It has an integrated webcam and an Intel Core i3 processor.
Unable to delete 0 byte file.
I was playing with batch files and accidentaly created a 0 byte, no extention file.
I googled the problem and I found out that closing explorer.exe and deleting the file via command would help. Tried that. It didn't help. Any software that could do it? Any other suggestions?
Thanks for your help in advance :)
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
7 Kommentare
Honestly, if its doing no harm to the laptop, you should probably just leave it.
von
It's taking up space on my desktop. I need that space :(
von
I would suggest using an administrative login to examine the file permissions. You need to open up the permissions and try the delete again afterwards. Windows file system permissions can make you want to resort to violence at times. Use of cygwin can help sometimes when all else fails.
von
If its just taking up space on the desktop, you can set the file to be hidden so you cannot see it unless you have view hidden files enabled. also what is this File Unlocker thing mentioned in the file description?
von
@professorc I doubt changing the permissions would do anything. Cygwin on the other hand might. I'll try that. Thanx for your help.
von
2 weitere Kommentare anzeigen
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
As I stated earlier.... Windows file system permissions can make you want to resort to violence at times. Use of cygwin can help sometimes when all else fails.
War diese Antwort hilfreich?
Bewertung 1
Hilfreichste Antwort
Create a new profile in Windows with admin privileges.
Log out of the current profile.
Log into the new one.
Use explorer to go to your other profiles desktop location.
Manually delete that file.
Bewertung 1
2 Kommentare:
Thanks for your answer but explorer.exe simply does not see the file as... a file. Creating a new account would probably do thesame as killing explorer.exe and deleting the file via cmd which did not help as I said in the question. Thanks anyway.
von
From the new profile open a new profile, open a command prompt with administrator privileages, and then use command prompt to navigate to where the 9 file is. Then "rmdir /s <file name> or del <file name>.
von
Antwort hinzufügen
SLimy wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 14
Insgesamt: 844
