Zum Hauptinhalt wechseln
Das Huawei Honor 8 ist ein Android Smartphone, das 2016 auf den Markt kam. Es ist mit einem 5,2" 1080 p Display, 4 GB RAM, einer 12 MP Doppelsensorkamera, einem Fingerabdrucksensor und einem USB-C Anschluss ausgestattet. Modell: FRD-L04
48 Fragen Alle anzeigen
Phone won't turn on after drop.
My Honor 8 won't turn on after drop. Only red LED lights while it is plugged in charger. Can you help me ? Phone is on first sight not damaged. Could it be display issue or some pins inside just disconnected? When I connect it to the PC it shows up and disconnect and this repeats.
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar:
I have the same problem but when i press the power button for a long time it shows "Honor" and it dies again the screen lights up for a second
von
Einen Kommentar hinzufügen
2 Antworten
Hello! An unprotected drop to a phone is likely fatal to your beloved device. Luckily, by your description, it only appears that your display and display and connection components are damaged. You can easily get this repaired at a professional repair shop.
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
So I need to replace whole display? %#*!^@. Thanks for your reply
von
It sounds like a component of your LCD display was damaged from the drop. I suggest replacing the LCD display on your device, which you can do by following this guide.
Bewertung 0
Antwort hinzufügen
Timotej wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 4
Letzte 30 Tage: 7
Insgesamt: 1,078
