No touch function after backlight repair (Advanced!)
Hi, this is my first question here.
I own a repair shop and do repairs on iPhone's for at last 3 years.
Now i got a iPhone 6s that drives me CRAZY!!!
A customer brought it in for a backlight damage, as always i checked the FL4211 for damage, none to bee seen also no burning, after i took of the CPU shield and the D4021 was a bit raised so i replaced it, after that the backlight came on and worked like a charm.
BUT, after the initial boot, the image on the screen was full of a pattern i have seen before, namely when you turn on a iPhone 6/6plus without the U2402 on. Vertical lines with some kind of checkered pattern.
I replaced 3 screens, cleaned the FPC, restored with latest os, nothing changed.
After i measured the "PP1V8_TOUCH_CONN" and here i found a open circuit, i made a strap on the "FL4209" and after that everything was in order with that line.
Still no touch function, i measured the following lines:
- "SPI_AP_TO_TOUCH_CS_L";
- "SPI_AP_TO_TOUCH_SCLK";
- "SPI_AP_TO_TOUCH_MOSI";
- "SPI_TOUCH_TO_AP_MISO";
- "TOUCH_TO_AP_INT_L";
- "AP_TO_TOUCH_CLK32K_RESET_L".
All of them give me a ~0.420V voltage drop to ground, no open circuit on any of them!
Also i mesured the "PP5V1_TOUCH_VDDH" when the phone was on and i got the 5.1V on that line.
I cannot understand what the problem is? Where am i missing something? There is no mechanical damage to the board, all SMD parts are in the right places.
Maybe someone has a ideea...
Thanks in advance.
D.
Ist dies eine gute Frage?
