Zum Hauptinhalt wechseln
Guides and repair information for the 4th generation of the BMW 7 Series / E65, E66, E67, and E68 platforms.
23 Fragen Alle anzeigen
Engines Stalls when going over 50 miles
i am having problem when the car is lean downward engine stalling or going over 50 mile. i have changed all the coils and plugs what else i should i do. the car engine code still shows miss fire cylinder 5 7 and 8
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
You may want to check the pressure on the fuel rail. You should also check the wire harness for the coil packs on the cylinders that are missing . Pay particular attention to the ground wire for the rail . with a hot engine carefully inspect the wires to the coil packs and to the injectors feel for mushy wires that blister up when the engine is hot. Hope this helps
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
Jesse singh wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 74
