Zum Hauptinhalt wechseln
Modell A1502 / 2,6 GHz (Turbo Boost bis zu 3,1 GHz) oder 2,8 GHz (Turbo Boost bis zu 3,3 GHz) Dual-Core Intel Core i7 Prozessor mit 4MB geteiltem L3 Cache.
494 Fragen Alle anzeigen
The MacBook won't boot with battery connected.
Hi all,
I have bought a MBP Retina mid 2014 that has suffered liquid damage.
The laptop works fine however it will not turn on when the internal battery is connected. I have tried changing the battery with no results. It works fine when connected to a charger.
Have you every faced this problem? If so did you find a solution to it?
Kind Regards,
Michael
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
my first suggestion would be to replace the battery, but seing as you have done that;
water damage has likely caused damage to a PLD used to process the battery. Try using a 99% Isopropyl and a new Toothbrush to scrub hard at the board around the connector. be sure to include local ICs.
If this doesnt work, it is likely a failure inside the IC, which would then need to be replaced. requiring SMT soldering. this is a developed skillset, and i dont suggest attempting it without proper practice ahead of time.
War diese Antwort hilfreich?
Bewertung 2
Your logic board has a problem! Charging logic likely has spill damage. You'll need to open the system and carefully inspect the chips on both sides and clean the logic board of any corrosion hopefully that will fix things.
Bewertung 0
Antwort hinzufügen
Michal Piatek wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 4
Insgesamt: 848
