Zum Hauptinhalt wechseln
4 inch display / Available in a variety of colors / Released in 3 different models / 16, 32, or 64 GB capacity
331 Fragen Alle anzeigen
How do I reset my iPod touch to its original factor setting?
My iPod is disabled for literally 5,760,000 minutes. I can't reset it because I can't find any information on how to do it. Please help me with this question.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 156
40 Kommentare
I cant do that because it wont let me. but thank you.
von
I have an iPod 5 and I upgraded it to iOS 8.2, and I am having problems. I have tried resetting it, but it is still having issues. How do I fix it to where it is perfectly fine? Please help.
von
well i have the ipod touch and i held the power button and than held the awake button and it leads me to the connect to itunes and i cant get off that like i want to get to my main home screen
von
I don't care if I lose all my information on it, I forgot the password to my iPod Touch 5th generation and I just want to reset it back to factory. How do I do this?
von
How do you just reset a 5th generation iPod to the factory system reset
von
35 weitere Kommentare anzeigen
Einen Kommentar hinzufügen
9 Antworten
Gewählte Lösung
Here is the Apple way: http://support.apple.com/kb/HT1414.
Use the following steps to restore your device:
1. Make sure you have the latest version of iTunes installed and running before attempting to update.
2. Connect your device to your computer.
3. Select your iPhone, iPad, or iPod touch when it appears in iTunes under Devices.
4. Select the Summary tab.
5. Select the Restore option.
6. When prompted to back up your settings before restoring, select the Back Up option (as seen in the image below). If you have just backed up the device, it is not necessary to create another.
7. Select the Restore option when iTunes prompts you (as long as you've backed up your device, you should not have to worry about restoring your phone).
8. Once the restore process has completed, the device restarts and displays the Apple logo while starting up
9. The final step is to restore your device from a previous backup. Once your device is restored and—in the case of the iPhone—in the process of activating, you should be able to see the following in iTunes:
iTunes window text: "Set up your iPhone... An iPhone has been previously synced with this computer."
Select the backup you want for your device and select the Continue button to complete your device's restoration.
If you do not want to restore from backup, select "Set up as new…" If you want to preserve previous backups that iTunes has made, be sure to back up the appropriate directory before choosing to set up as new.
Or you can just do it this way, though the steps may be different for your OS: Settings --> General --> Reset --> Erase All Content and Settings
This process is quicker and erases ALL content of your iPod. The only problem with that is that it also erases EVERYTHING. So after doing that, you'll have to connect to iTunes and install firmware. This could install software that does not allow you to jailbreak it. So you may have to do a shift/restore if you jailbreak and download a firmware version that enables jailbreaking. Good luck. I hope this has helped a little.
Or you could just wait for about 10yrs :-)
Good luck to you.
War diese Antwort hilfreich?
Bewertung 12
5 Kommentare:
+ very complete answer
von
I Like your idea, but the thing is that my iPod for a reason dont connect to the device im trying to, i think is because of the charger device, but i dont know, would have any tips?
von
I bought mine at a lost and found sale. Before it will display the summary tab, it requires the old pass code. Sadly, nobody seems to know what it it.
von
not helpful please help me fix my ipod
von
Not real helpful bought mine at a lost and found sale in the Bay Area. It already has someone else's apple account in on it trying to open an apple account and it won't do it. Now I try to download some it wants this other person password. I don't know it. So what can I do?????
von
Hilfreichste Antwort
To reset iPod touch, press and hold the Sleep/Wake button and the Home button at the same time until you see the Apple logo show up on the screen
Bewertung 17
2 Kommentare:
Didn't Work .
von
Need the pass code to do this.
von
'''Disconnect all cables from your device.
Hold down the Sleep/Wake button, then "slide to power off" to turn off your device.
Press and hold the Home button and plug the device into your computer. If your device doesn't turn on automatically, turn it on. Don't release the Home button.
Continue holding the Home button until you see the Connect to iTunes screen.
If iTunes doesn't open automatically, open it. iTunes will alert you that it has detected a device in recovery mode.
Click OK. Then restore the device.
This will erase the device and its passcode.'''
Bewertung 3
you can not, because it is not in DFU mode.
Put the iPod into DFU mode, then you get to format the iPhone in iTunes.
""Put the device into DFU mode.""
DFU MODE STEPS
Hold the Power Button (3 secs)
Continue holding the power button and also hold the home button (15 secs)
Release the power button while continuing to hold the home button (10 secs)
Your device should prompt with the "Connect to iTunes Screen"
Second: Plug it into your computer and open iTunes. It will either prompt to restore and up date or you can manually restore using the following steps.
Now follow the steps in iTunes
https://support.apple.com/en-us/HT201252
Bewertung 2
2 Kommentare:
I do not have a computer so what else do you have for me.?
von
I bought my iPod at a lost and found sale. These steps will not work unless I use the original code--which I don't have.
von
Press and hold ur home button and power button Intel it shows plug in to iTunes and connect it to iTunes and wholea I got ur iPod to factory settings
Bewertung 2
1 Kommentar:
thank you this one worked.... finally able to access my ipod
von
https://support.apple.com/en-au/HT204306
Forgot passcode for your iPhone, iPad, or iPod touch, or your device is disabled
Learn what to do if you have forgotten your iOS device passcode, or if your device displays a message saying that it's disabled.
If you enter the wrong passcode into an iOS device six times in a row, you'll be locked out. You'll also see a message that says your device is disabled.
iPhone is disabled
iPad is disabled
iPod touch is disabled
Erase and restore
If you can't remember your passcode, you'll need to erase your device, then use a backup to put your data and settings back on your device.
Recovery
Mode
Use these steps if
you've synced your
device with iTunes.
Use these steps if you
have an iCloud account
and have Find My iPhone
turned on. Use recovery mode if you
can't sync or connect with
iTunes and don't have an
iCloud account.
iTunes
If you've synced your device with iTunes, you can restore your device.
Connect the device to the computer you normally sync with.
Open iTunes. If iTunes asks you to enter your passcode or asks you to allow access, try another computer that you've synced with. Or use recovery mode. (Click the link to be taken to the steps.)
iTunes will automatically sync your device and create a backup. If it doesn't, sync the device with iTunes.
After the sync is complete, restore your device.
When iOS Setup Assistant asks to set up your device, choose "Restore from iTunes backup."
Select your device in iTunes and choose the most recent backup.
Find My iPhone
If you enabled Find My iPhone through iCloud, you can use it to erase your device.
Go to icloud.com/find.
If prompted, sign in with your iCloud Apple ID.
Click All Devices at the top of your browser window.
Select the device you want to erase.
Click "Erase [device]" to erase your device and its passcode.
Use the Setup Assistant on your device to restore the most recent backup.
Recovery mode
If you've never synced your device with iTunes, or haven't set up Find My iPhone, you'll need to put your device in recovery mode. Then you'll restore your device as new or from a backup.
If your device doesn't go into recovery mode, try steps 1–4 again.
Bewertung 0
1. Shut off your ipod touch
2. hold the sleep\awake and the power bottun until the itunes comes up
3. go to itunes it will say u cant do this.............
4. clike retry and it itunes will say the details
5. click restore
6. it will say restore and update
7. then it will say agree hit agree then it will restore
Bewertung 0
You need a computer with itunes on it connect your apple device to you computer open itunes and then go to about phone and click reset and restore
Bewertung 0
There are numerous individuals available that have accessibility to the Musical.ly neighborhood. Such a huge number results from the worthwhile functions. musically Musical.ly likewise showcases a number of competitions difficulties to maintain.
Bewertung 0
Antwort hinzufügen
Meagan Stone wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 10
Letzte 30 Tage: 48
Insgesamt: 381,879
