Zum Hauptinhalt wechseln
Verkaufsstart Juni 2012, Model A1278. Intel Prozessor mit Turbo Boost
1624 Fragen Alle anzeigen
Liquid leakage. Totally damaged.
So, my Mac Pro (13.3 – Model A 1238) was totally wet one morning. There was a pool of liquid under it, and when I lifted it, a lot of liquid came pouring out from left side contact holes. Has anyone experienced anything like it? Took it immediately to authorized service: “Totally damaged. Liquid leakage. Impossible to repair. ” Thank you! Maria Francisca
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
Ediciones Satori let's see if @reecee or @tcrs_circuit can help you with this. Don't give up just yet. Let the gurus guide you....
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Repair is most defiantly possible.
Authorized repair often is clueless about these devices.
If you have a small phillips screw driver, Please flip the laptop over and unscrew the bottom cover. When this is done, please unplug the battery. When that is done, We are going to want to take that logic board out and clean it really well with isoproyl alcohol. You can do this trust me! It's not that diffficult!!
Here are some guides on how to do that. You will need a torx screw driver to take the board out.
MacBook Pro (13 Zoll, Mitte 2012, Unibody) Logic Board Austausch
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
Ediciones Satori wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 104
