Zum Hauptinhalt wechseln
Reparaturanleitungen für Grafikkarten
111 Fragen Alle anzeigen
monitor is flashing with new graphics card Asus strix GTX 1070.
ISSUE: Screen flashing, Dirty rendering when on desktop but clean graphics when inside a game (DOTA2)
System: Asus TUF z270 mk1, Intel i7 7700K, Kingston 8GB*2 DDR4, Asus Strix gtx1070 8GB OC, Samsung 960 evo & 850 evo SSD,
DETAILS: I have just bought an Asus Strix graphics card to replace my PALIT GTX 650ti (mixing the newly purchased mobo and CPU with an old graphics card wasn't good. It had random episodes of extreme lags even when not gaming which I thought was due to GPU bottleneck)
So my Asus Strix Graphics card flashes my screen randomly, The screen rendering was also noisy (tiny random red dots on screen). Despite using both the driver on the CD that came along the GPU and the one downloaded from the NVIDIA bsite.
[] I've followed basic and advanced trouble shooting by reseating the graphics card, ensuring the PSU (8) pins fitted, totally removing the previous driver (gtx 650 ti) using DDU (display driver uninstaller) while on windows Safe Mode, uninstalling Norton antivirus, disabling Cortana. Disabling the IGPU (integrated graphics) from Bios. Even disabled the Audio driver (as some have suggested online). None of which have worked, the screen still flashes and with lots of random tiny red dots everywhere.
[] I also did a clean install of windows 10 and it worked just a little (no more random red dots when graphics is set to 60Hz- anything lower will still make the red dots visible) but the screen still Flashes randomly.
[] lastly I booted a windows 8 OS from my other SSD and the flashing and noisy rendering continued as soon as I've installed the graphics driver from the CD, and even when updated with the latest release from NVIDIA (I concluded this isnt just WIN 10 messing up with me).
I am at the point of just wanting to run on safe mode all the time or to just ditch the entire rig. I have built a few systems in the past and this is the only time I've had this issue.
NOTE/ CLUE:
1. screen seems fine when running on windows SAFE MODE. Issue resumes when the display driver is installed.
2. Screen rendering is exceptionally CLEAN when I was playing DOTA2 but becomes noisy again once I'm out of the game i.e desktop.
3. I wanted to try win7 but I think ASUS tuf z270 doesnt have win 7 drivers (doesnt "officially" support OS below win10)
4. I've also had display issues In the past when I was using the IGPU (HDMI cable connected the onboard HDMI port) with this motherboard. so I'm not sure if other components are to blame in this case.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
Ok this is a weird issue... have you tried another cable? Also if the card is new, cant' you get a replacement?
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hi @volcob, please let us know your computer power supply, , made, model, etc. There are cases that weak power supply, causes this weird issues, you mentioned you recently brought the asus graphic card, another best way is to send it to the service centre / shop to test on spot.
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
Stephen Chen wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 3
Insgesamt: 1,770
