Zum Hauptinhalt wechseln
Reparaturanleitung und Informationen zur Fehlerdiagnose für die kabellose Apple-Maus mit Multi-Touch-Unterstützung. Modellnummer A1657 oder A3204.
Cannot select with MM2.
Cannot select with MM2. I can move cursor but cannot click. Also disables my ability to select on trackpad. If I turn off MM2, trackpad functions normally.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 3
1 Kommentar
Hello!
I had the same problem with the MM2. I could move the pointer but it did not go right or left click. Have a reset of the mouse performed, tried on another Mac.
Nothing worked!
Then I disassembled the mouse according to ifixit instructions and, as in step 7, disconnected and reconnected the data cable.
And the mouse works again like the first day!
I hope I can help some users with the info, because I found nothing on the Internet.
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Try going to system preferences > trackpad > see if "tap to click" box is checked.
War diese Antwort hilfreich?
Bewertung 2
2 Kommentare:
Thanks, I can select with the trackpad as long as the Apple mouse is disconnected. I am using a cheap external mouse and getting by. I think the Apple mouse is my problem. At $75 I'm going to have to make do with the off-brand mouse. It has made me become more proficient with the trackpad.
von
Well. get a used one, I just bought 4 for $45 https://www.ebay.com/usr/tricomputersolu...
von
Antwort hinzufügen
James M McMurtry wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 4
Letzte 30 Tage: 17
Insgesamt: 1,468
