1978 f100 front caliper frozen. Retaining Pin will nor release
Is there a technique in removing the retaining pin from brake caliper? Driver's side punched out with a moderate amount of effort but the passenger side will not release. Passenger side caliper is frozen and wheel will not roll. C clamp against pad does not retract cylinder.
Ist dies eine gute Frage?
1 Kommentar
My answer to the question is that the slide pin can be removed by using a punch and a hammer but the kicker is that the slide pin can be punched from the inner side (from the tie rod) outward or from the outer side inward. I punched from the inner side outward on the driver side caliper with success but it is the dumb way. Much easier punching from the outside inward. Did this on the passenger's side and it was easy.
von Chincoteaguer
