Zum Hauptinhalt wechseln
Reparaturanleitungen, Handbücher und Hilfe bei der Fehlersuche für Apple LED Cinema Display 27". Hier findest du alles, was du für deine Apple LED Cinema Display 27" Reparatur brauchst.
Display won't turn on. Power works
Hello!
I have this apple display which doesn't work. The magsafe works, the USB works, the speakers works, and the computer recognises the screen, in the screen settings. However there is no display in the screen. I've disassembled the display, and no fuses seems broken on either power supply or the logic board. Could someone gie me a hint towards which of the two to replace? Could this maybe be a cable?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Take a flashlight and with the system & display all hooked up and running see if you can see the faint image of your desktop by placing the flashlight on the glass at a sharp angle. If you do your backlight logic needs repair. The LED driver logic chip has a tendency to burnout on these displays.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Christian Holm wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 2,451
