Zum Hauptinhalt wechseln
Vierte iPhone Generation. Die Reparatur an sich ist unkompliziert, aber Frontglas und LCD müssen gemeinsam ersetzt werden. GSM mit 8, 16 oder 32 GB Kapazität, Modell A1332 in schwarz und weiß.
2399 Fragen Alle anzeigen
Back panel will not slide back on?
I followed the guides within here to take apart my iPhone 4. And made sure to follow and remember every screw I took out, etc. My question is, whenever I go back to slide the back cover back on...it will not fully slide down into position for the two holes to screw it in place...it seems to be "stuck"... any ideas?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
you need to put a little bit of force, and check out the outter frame that it is aligned with the housing as u slide it on. :)
War diese Antwort hilfreich?
Bewertung 5
3 Kommentare:
Thankyou! Put a little more force on it, and bingo, "clicked" right into place no problem. Thanks! :)
von
Please "accept" an answer if it solved your problem so that it can be archived for others to learn from. Thanks
von
You guys helped me out too! I thought I was going to have to reassemple everything. Then I was scared to apply more pressure. Thanks Guys! Who needs apple care?! IFIXIT!
von
This has happened to me a lot and i have found that the reason being, for me at least, is that i forget to make sure the 6 side screws (with washers) aren't tighten all the way. After i retighten those it fits like a charm!
Bewertung 1
I just broke the !@#$ out of hte back of my iphone doing htis
Bewertung 0
Antwort hinzufügen
Ryan wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 17
Insgesamt: 9,051
