Zum Hauptinhalt wechseln
Das Samsung Galaxy Note 4 ist ein Smartphone, das im Oktober 2014 heraus kam. Die Modellnummer des Galaxy Note 4 ist bei der amerikanischen Variante eine der folgenden: SM-N910, SM-N910A, SM-N910T, SM-N910V, oder SM-N910R4.
256 Fragen Alle anzeigen
My GALAXY NOTE EDGE WONT TURN ON
Hi , i need help, i have the same problem on my GALAXY NOTE EDGE , I posted here because it seems that Note 4 and Note Edge are similar, anyways , my phone started freezing and working slow , and lately started shutting off by itself and demanding a reboot and it didnt work so everytime i take the battery off for a few minuts and turn it on again and it works after trying for couple times or sometimes he start easy from the first try, and it keeps doing that for about two weeks , but last night he shut off and never came back to life , i tried everything , the repoot trick by holing the home buttom nd the volume one , tried to take the battery off and hold on the power key for 1 min , 2 min, 3 min .... and more and then put back the battery and never owrked to ... i dont know what to do , i dont want to loose my phone , arround 10 GB videos and picturs and documents are stuck there and i dont know what to do, do please any help ???/ any suggessions ??? sorry for my english if there is any mistakes , PLEASE LET ME KNOW IF THERE IS ANY MISSING INFORMATION
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
Try a new high quality battery replacement. The Note 4/Edge are strangely sensitive to batteries.
War diese Antwort hilfreich?
Bewertung 1
Sounds like a bad battery. Replacing it will most likely help. If this doesn’t work, it may be the components inside the phone that the battery connects to. Sadly, I couldn’t find a teardown for this device.
Bewertung 1
Take out the battery, put the phone in the freezer for 5 min, take it out, put battery back on power it and when it turns on plug it to a charger
Is a temporary solution, the phone will shut down eventually, I'm trying to find a real fix
Bewertung 0
Antwort hinzufügen
MANNAI wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 11
Letzte 30 Tage: 17
Insgesamt: 3,301
