Zum Hauptinhalt wechseln
The final generation of the Buick Century was released in late 1996 for the 1997 model year.
16 Fragen Alle anzeigen
Why does my Buick sputter, accelerate on its own and is hard to stop?
A couple days ago my 99 Buick century suddenly started sputtering, backfiring and most the time will accelerate hard on its own while backing up, or pulling off from stop. Its cut off a couple times now at red lights. My brakes suddenly became hard to push in as well and is becoming harder and harder to stop. I know the two probably aren't connected, but can someone please tell me what it may be? Thanks!
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar
@jimfixer what do you think about this one?
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Actually Candy the two problems may be connected . You brakes are boosted by a vacuum pump to give you power assist on the brakes and your car sounds like it could possibly have a vacuum leak in the intake manifold which would cause the engine to run like a POS. This can cause erratic idle speeds and backfiring and if the vacuums not there then neither is your power assist on your brakes . The quickest way to find a vacuum leak is to start the car leave it at an idle and take a propane torch ,not lit, but with the gas on and slowly move it around the intake maifold until you notice an increase in the idle speed . Thats were you,ll find the leak .Hope this helps
War diese Antwort hilfreich?
Bewertung 3
Antwort hinzufügen
Candy Williams wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 27
Insgesamt: 958
