Zum Hauptinhalt wechseln
Launched in 2012, the Asus X54C features an Intel Pentium Intel® Core™ i3 Processor, Intel® Pentium® Dual-Core Processor and Intel® Celeron® Dual-Core Processor
17 Fragen Alle anzeigen
My Asus X54H, wont power on. Power supply is working good.
My Asus X54H wont power on. Power supply is good as i used it on other laptop and its working. When i power it on, only 2 led lights remain on; 1 green led and 1 red led. pls help
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
4 Kommentare
Which lights are on? and which colors are on with each light?
von
@fcaancan If you figured it out please say what you did so other people can fix their issue if they come across one like yours. Thanks!
von
I havent figured it out. The power indicator light switches on (green led) & the battery indicator light is also on (orange led). But the OS LED light does not turn on. A friend told me my HDD could be damaged and suggested to replace it.
von
Hi @fcaancan, is there any display output on your computer screen? If so, try follow ayeff advice to check on the HDD first :)
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hi @fcaancan
Get into BIOS on power up to check if the HDD is being detected. If not check that the HDD connection is OK
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
Fred caancan wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 4
Letzte 30 Tage: 12
Insgesamt: 747
