Power On No display
Its Power on but gives display sometimes and sometimes not give display
Ist dies eine gute Frage?
Hi,
Connect an external monitor and check if it shows a display OK.
Also when the laptop screen shows no display, use a torch and shine it at an angle close to the screen and check if you can detect a display at all. It will be very faint so perhaps it will be easier if you try this in a darkened room
War diese Antwort hilfreich?
try to open it up and disconnect the screen then clean the screen connectors with alcohol assembleitup and retry
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 5
Insgesamt: 726
1 Kommentar
maybe a loose cable
von daniel
