Zum Hauptinhalt wechseln
Herausgegeben am 25. September 2015. Model A1687/A1634. Die Reparatur des 6s Plus gestaltet sich ähnlich zu denen früherer Generationen; benötigt werden Schraubenzieher und Hebelwerkzeuge. Verfügbar mit GSM oder CDMA / 16, 64 oder 128 GB / Silber, Gold, Space Grau oder Roségold.
1041 Fragen Alle anzeigen
Help with right temperatures for microsoldering
I want to replace the FPC Battery Connector Clip since its broken and my iphone wont turn on. what temperature setting should my hot air work station be set to and what temperature should my soldering iron be set to? any help would be greatly appreciated.
I tried to look for a youtube video or online guide for this procedure but was unable to find one. thanks.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
@freshstylez check with our expert @refectio or @teetopp for that.
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Soldering FPC connectors is tricky because too much heat will melt the plastic. The actual heat setting is not that critical because depending on how close your hot air nozzle is and how much air flow to the connector can make a huge difference.
Fundamentally speaking, you need to get the solder to flow. Depending on which alloy you use, you need to get the pcb/solder connection up to 183-190C. How you get there is what determines if you damage the plastic. You could blast it with 360C if you stay a reasonable distance away or you could go low at 275C and take your time. This is where the "artisanry" comes in...you have to practice a lot to get the right amount of heat to the pcb but not more than you need. As they say practice makes perfect.
Try different settings and see what works best for you. Some people like to tin the pads, others like clean and bare pads. Some like to "tack" the connector in place, others like to let the connector flow. Some like to do this with hot air, others like using micro-tweezers. It also depends on how much room you have on the pcb and how big the connector is. You'll need to develop your style, there is no set way to do this.
War diese Antwort hilfreich?
Bewertung 8
Antwort hinzufügen
Richard Rivera wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 6
Letzte 30 Tage: 23
Insgesamt: 5,544
