Zum Hauptinhalt wechseln
Das iPhone 6 mit dem 4,7 Zoll Display ist die kleinere Version des iPhone 6 Plus und kam am 19. September 2014 auf dem Markt. Es hat die Modelnnummern A1549, A1586 und A1589.
4994 Fragen Alle anzeigen
iPhone recognized in iTunes, but no other signs of life?
I bought a broken iPhone 6 on eBay for the sole purpose of using the logic board to fix my iCloud locked iPhone 6. The phone was extremely damaged, the top 10% or so almost looked shredded. The logic board looked intact, however it slightly bends down on the border of the display connectors and the motherboard, about 20 degrees or so. I installed the logic board, charged it for a while, and it was recognized in iTunes, but I could make out nothing. The phone made no vibrations or noises, and changing the ringer has no effect. The logic board had water damage, the SIM tray indicator was tinged red, so nothing too severe. Is there something else besides the backlight that could be faulty, to cause the phone to be unable to make sound or vibrations?
Thank you in advance for any assistance.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
Just to add: It's passcode locked, and not in recovery mode.
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
The bend and the liquid damage are big red flags itself. A slight bend could cause the fragile paths of the motherboard to break. Liquid could also cause big issues with the device not showing an image. What I would try is to clean the board with alcohol to rid of any corrosion then rinse the motherboard with distilled water and dish soap, dish soap leaves no residue. If you have a sonic cleaner I'd make use of it. As for the bend I'd try to mend back in place to see if can make reconnections with between the paths.
Word of advice I would just shell out the extra to get a full device since a refurbished iPhone 6 with a warranty is around the same price as a motherboard from a reputable source. With a used motherboard from a broken device could be very problematic and could also be iCloud locked.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
I got the motherboard off eBay for just $20. Where I live, it's harder to come across good deals for unlocked phones, the markup and shipping cost are huge.
von
Antwort hinzufügen
Eric Zhang wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 76
