Zum Hauptinhalt wechseln
The fourth generation Nissan Altima (chassis model L32A) was announced at the 2006 New York Auto Show on April 12, 2006. It was the first vehicle to use the smaller Nissan D platform, with a new front and upgraded rear suspension.
Power window switch sometimes not working
Power window driver's side switch sometimes not working
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 3
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hi @ypoop ,
Here is a video that shows how to remove the window switch console of your vehicle so that access can be gained to the wiring at the back of the switch unit.
Here is a video that shows how to determine if the problem is in the switch unit or perhaps in the wiring to the window motor or in the window motor itself. (This video is not for your model vehicle as far as I know, rather it shows the testing procedure to find where the problem might be)
Hopefully this is of some help to you in tracking down the problem
War diese Antwort hilfreich?
Bewertung 4
Antwort hinzufügen
ypoop wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 5
Letzte 30 Tage: 29
Insgesamt: 26,931
