Zum Hauptinhalt wechseln
Das Galaxy S7 Edge ist die Variante mit gekrümmtem Bildschirm von Samsungs 2016 Flaggschiff-Smartphone, dem Galaxy S7. Angekündigt im Februar 2016 und am 11. März 2016 veröffentlicht. Modell SM-G935.
How do I by pass my Frp lock
How do i by pass my Frp lock on my galaxy s7 edge
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 19
10 Kommentare
Has anyone tried it lately? I have also the model SM-935F and I tried to flash it with Odin and the newest firmware. But it didnt work. Has any one an idea how to bypass the FRP?
von
use https://youtubewala.com forum to fix the issue
von
Using the FRP tool (https://minerev.com/frp-bypass/), you can easily bypass the FRP lock.
von
I think using vROM ByPass APK will help. Get one from here (https://clashmod.net/vnrom-bypass-apk/)
von
You can bypass any phone location using the bypass apk: https://youtech.ooo/frp-bypass-apk/
von
5 weitere Kommentare anzeigen
Einen Kommentar hinzufügen
12 Antworten
Gewählte Lösung
You need to flash the unit utilizing Odin. It's Factory Reset Protection, so the only way to override it is flashing.
You need a windows pc, Odin Software, and the flash file for your unit. I believe the file you're going to be looking for is for SM-935F. You can verify this on that lock screen, if not put it to download mode and it will tell you the unit type.
Entering Odin Mode on Samsung:
Hold Side key, Vol Down, and home button. Screen will jump to Odin/Download mode.
Good Luck
War diese Antwort hilfreich?
Bewertung 14
2 Kommentare:
Model number is never displayed on the lock screen.
von
Checked one, says it on 2nd line. "product name"
von
Info on how to bypass FRP here:
http://forum.gsmhosting.com/vbb/f777/uni...
Requires factory resetting the phone which user data is wiped and downgrading the phone to 6.x.
If you have a Z3X flashing box or something similar to that you can skip all the steps and use the one click FRP unlock that way.
Bewertung 5
Just follow this video step by step and you can bypass your frp lock on galaxy edge 7 easily
https://youtu.be/XHZGoGd8yHo
Bewertung 5
1 Kommentar:
There are many ways to bypass frp lock but if you searching for latest video tutorial so here it is follow video step by step
https://youtu.be/ejSmVmCaU3c
von
In fact, Google account and Google password is the quickest and effective method to bypass FRP lock on Samsung, ask the owner or the seller to provide the Google account, the ODIN software is complex to remove FRP lock on Samsung, and it’s too professional to operate.
The newest and easiest method to remove FRP lock on Samsung is the tool-Eelphone Google Account Removal, just several clicks during the whole process.
Bewertung 2
There is an app for samsung phones called TEST DPC. It lets you run the phone by owner or administrator. It works very well. Free also.
Bewertung 2
I found how to do it.
Flash old firmware, then reboot to the menu where i can reset factory default… RebbotReboot and then i was able to enter my account there.
So we need to play with old firmware, than old power and volume to go in the menu where we can access the Android Factory default menu.
Bewertung 2
Hi. Here are a video https://www.youtube.com/watch?v=r5vVos4e... “How do I by pass my Frp lock”
To See this video, you can easily understand how do i pass my frp lock.
Bewertung 2
You can use a few tools to bypass FRP lock, but to mention, in particular, DroidKit is capable of removing FRP lock.
Bewertung 2
All Samsung Galaxy Direct FRP Unlock || Android 9/10/11/12 || No Backup || Samsung A8 2018 FRP
https://youtu.be/l1UDvTKyaik
Bewertung 2
To do this you must have frp bypass app. If you have not then you can get from here: https://apkvow.com/frp-bypass-apk/com-fr...
Bewertung 2
YouTube, no software or computer required. Quick search and you’ll find what you want. I’ve done loads that way.
Bewertung 2
Download app called TEST DPC , it resets it completely. Restarts and ask if you want to be device owner. It works, I just unlocked my samsung j7 with that app. How to download it to your device is turn on accessabilty moood, go to settings under talk back settings then go to android setting up switch, it will show youtube, then go to settings in youtube. Go to privacy for youtube. It will take you to internet. Then just type in test dpc. Download the app. Open and set up.
Bewertung 1
1 Kommentar:
Thanks for the information. Much appreciated.
von
Antwort hinzufügen
Chris bean wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 12
Letzte 7 Tage: 48
Letzte 30 Tage: 232
Insgesamt: 55,698
