Zum Hauptinhalt wechseln
Modell A1059 oder A1099 / 20, 40, oder 60 GB Festplatte/berührungsempfindliches Klickrad
227 Fragen Alle anzeigen
Frage geschlossen
Hard drive cable has disconnected how do I re-connect it?
I have seen the guide about lifting up the flap on the connecting strip, however my IPOD Photo does not have this connecter and the hard drive cable is seemingly only held on by tape?!?!?!
I have it all in pieces with new parts but cannot figure out how to re-attach this cable.
Ideas?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
just a really simple question. Did you check under the tape? Every iPod that i have has the tape over the connector. like iTronicsRepair mentioned, look for the black locking tab on the connector and you will have to flip it toward the cable to open the connector.
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
If you do not see the little (i believe black) tab that should flip down to hold the hard drive connector in place, there is a good chance it has been broken off the motherboard. You can either try to just stick in the hard drive connector and hold it on with tape (probably not a good long term solution) or you'll probably need to get a new motherboard.
War diese Antwort hilfreich?
Bewertung 0
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 1,038
