there are plenty of things that can cause this symptom. The basics is that it is either a software corruption, or the screen is recieving some of the charging current. this can be for multiple reasons. the process of solutions are as follows, from least-most expensive.
1) start with a factory reset, and see if it fixes the issue. (This will erase all of your data.)
2) re-flash the stock ROM to the device. (this will put new core files onto your phone. (a standard reset keeps the core files from your previous software. if there is a corruption in core files, you will not be able to get rid of it with a basic factory reset)
3) Charge port: There could be a short in your SubPBA, which will need to be replaced if that is the case.
4) Screen failure: There could be a short in your screen, causing a flicker when excess current is introduced to the device.
5) board level failure: a possible filter malfunction could be causing the issues. (to fix this you will need a multimeter, the Board Diagram -with indexes, and Surface mount soldering skills) if you do not have the required items and skills, then replacing the motherboard is also a solution.
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
0
Abbrechen
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
My samsung handphone screen flashing on and off while charging
von Mohammad Haffit Md Talib
