Zum Hauptinhalt wechseln
The ZTE ZMax Pro is identified by its black color, rear fingerprint sensor and its model name, Z981, which can be found under the rear case.
133 Fragen Alle anzeigen
Cant download app please help
I have a ZTE Majesty Pro LTE the Google Play Store on it is acting up. I cant download anything it keep saying Can't Download App and I just got this the other day... Please help and I was thinking could a factory reset help..
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
4 Kommentare
I have a ZTE smartphone and cant download apps please help
von
Hi @avajean ,
Have you tried the suggestions in the Chosen Solution below?
Can you access the internet OK otherwise?
What is the model number of your ZTE phone?
von
yes I've checked just about everything on this phone am about to toss it if I can't get help to figure it out
von
My sister tryed to get on it and with so many bad passwords it reset and it won't download anything I've even tried getting them on the internet and it won't work I've tried downloading every app I could think of but nothing I've tried to reset it again but nothing
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Hi,
Can you access and download content from the internet OK?
If so check that the Play Store app is up to date.
Go to Play Store > Settings >scroll down to Build Number > tap to enter. If there is an update available follow the prompts.
Once update has been completed try again
War diese Antwort hilfreich?
Bewertung 4
1 Kommentar:
Thanks I went ahead and did a factory reset that helped....
von
do a factory reset and it should not have a problem
Bewertung 0
1 Kommentar:
ZTE will not download and I do not want to do a factory reset
von
Antwort hinzufügen
raff jones wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 2
Letzte 30 Tage: 5
Insgesamt: 7,632
