I have a $70 Blu phone and I've run out of space a lot. Our friends at Google like to push updates on me, and there's a bunch of crapware that I never use but can't delete.
I presume you've gone to the Settings--> Device--> Storage -->set the default storage to the SD card.
You can also try going to settings--> Device-->Apps and go through each app. Some have a button to move to the SD card. Disable ones you don't use, uninstall them if you can, clear the cache (some say "manage space"). The next step is to uninstall updates. Sometimes you will get a lot of space back. They seem to keep all the old updates just in case you want to use them ....?
Anyway, the next thing to do is reset your phone completely. You can probably get back half your internal storage, because that's what it came with. Google will immediately start filling it up again, but at least you're starting fresh. Kind of drastic, because you'll have to fiddle with it to get back to the way you like it.
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
Hi @kevin07 ,
If you have a lot of music files or pictures or ringtones etc on your phone you can create space in your internal storage by moving the files to the SD card.
von jayeff
Thank you for your answer jayeff but I don't. Even if i had, it won't be enough so i can install apps on my internal memory but thank anyway.
von Kevin
Anyone else have an answer that could help me ?
von Kevin
von Kevin
