Sound Muffled without Headset
People describe me as muffled, talking in a cave, or breaking up when I'm not on the headset. Sounds like there's a problem with my mic. What can I do?
Ist dies eine gute Frage?
Hi @nygal ,
Use a strong light and a magnifying glass to visually inspect the voice inlet hole, found on the bottom edge of the phone, to see if it is blocked with dust or lint.
If it appears to be blocked use a vacuum cleaner, using short sharp bursts, to try and clear the obstruction.
If you don't have a magnifying glass try the vacuum cleaner anyway and then make or receive a call to test if it has been fixed.
Do not use a probe to try and clear it as the phone's microphone is directly behind the hole and could be damaged if you do.
War diese Antwort hilfreich?
Helpful but it didn't fix the problem, unfortunately.
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 244
