Zum Hauptinhalt wechseln
The BlackBerry Priv is a slider smartphone developed by BlackBerry Limited. Following a series of leaks, it was officially announced by BlackBerry CEO John Chen on September 25, 2015, with pre-orders opening on October 23, 2015 for a release on November 6, 2015. It can run up to Android 6.0.1.
23 Fragen Alle anzeigen
Power button only works with pressure against back of phone.
Like the title says, if I press hard against the back cover of the phone directly below the power button the button will function normally, but the second I take pressure off it no longer works. It clicks as usual but does not turn the screen on or off. Given the Priv's nature as a slide phone, I worry it has something to do with the mechanism and that the repair may be intensive. Hopefully someone out there can help, not having a power button can be pretty annoying. I'm more than willing to give any other information that may be relevant.
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Got the issue several days ago. Gonna disassemble my phone tonight and check it.
Seems the button is on the flexible cable, so hopefully I can just resolder it to the mainboard.
However, given the nature of the issue, it might be soldering problem for a power controller chip, that would be harder.
AFAIK the problem is massive, there are few similar reports at Crackberry :(
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
Oleg, did you find out the source of the problem with the power button? I've got the same issue and have some electronics skills, would like to fix.
von
Antwort hinzufügen
Patrick Schmalz wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 3
Insgesamt: 1,251
