Zum Hauptinhalt wechseln
Reparaturanleitungen, Demontage- und Fehlerdiagnose-Informationen für die 4. Generation des Apple iPad mit GSM 4G LTE-Mobilfunknetz (AT&T), erhältlich mit 16, 32, 64 oder 128 GB Speicherplatz. Veröffentlicht im November 2012. Identifiziert durch die Modellnummer A1459.
no wifi greyed out.
I have an iPad 4 GSM and the wifi and bluetooth switch is greyed out. the iPad has never been dropped or been exposed to water. It is in pristine condition. I tried a method of placing the iPad in the freezer for 15 min and when i took it out, the wifi and bluetooth started working again. Unfortunately, it was only a temporary fix. What should i do to fix this myself. Is it possible to find the exact wifi chip and replace myself. Any help would be greatly appreciated. Thanks.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hello!
It seems that the IC in charge of that task (usually wifi and bluetooth are going right) is damaged or is "separating" from the motherboard. The only solution is to change it (I do not advise reflow)
You need a technician specialized in that type of repairs or it will hurt more than repair. It is a delicate repair and you need tools and many hours of training to do it. I advise you to look for a specialized technician in your area or request a quote from a partner of iFixit.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Richard Rivera wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 11
Insgesamt: 311
