Apple's Mac Mini is a desktop computer that differs from most of the company's other consumer models in that it lacks an integrated monitor. As with any computer, you may encounter the occasional software glitch that will render your Mac Mini unresponsive to input -- requiring a restart. A basic hard reset is enough to correct most problems, but if you encounter issues with your computer not powering up properly or failing to recover from sleep, a Power Management Unit or System Management Controller reset may prove necessary.
Basic Hard Reset
Step
Locate the power button, installed on the left side of the rear panel.
Step
Depress the power button until the computer powers down.
Step
Press the power button again to restart the computer.
PMU Reset (PowerPC)
Step
Disconnect the Mac Mini's power cord, as well as any other cables that may be connected to the computer. Wait 10 seconds before proceeding.
Step
Hold down the computer's power button, then reconnect the power cord. Release the power button.
Step
Press the power button to turn on the computer.
SMC Reset (Intel)
Step
Disconnect the Mac Mini's power cord. Hold down the power button for 5 seconds.
Step
Release the power button. Reconnect the power cord.
Step
Here's how to reset your PRAM:
Shut down your machine. Yes, all the way down, not sleep or logging out.
Press the power button and then press command-option-p-r. ...
Hold those keys down until your Mac reboots again and you here the startup chime.
Let go of the keys and let your Mac reboot normally.
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
3
Abbrechen
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
1 Kommentar
@mayer Sorry we answered at the same time.. Mayer is correct
von joe
