Zum Hauptinhalt wechseln
Fünfte Generation des iPhones. Die Reparatur dieses Geräts ist unkompliziert und mithilfe von Schraubendrehern, Hebelwerkzeugen und Geduld zu machen. GSM und CDMA mit 16, 32 oder 64 GB in schwarz oder weiß.
2193 Fragen Alle anzeigen
4S neither of 2 new batteries holds charge for 24 hrs.
I have replaced batteries in both 4s and 5s models before with success.
Currently, I've replaced battery in a 4s twice (both new batteries) but it will completely drain to 0% while sitting unused with no apps running, even in airplane mode.
If both new replacement batteries were not faulty, what do you suppose could be the problem.
Make any suggestions? I' let you know if they helped. Thank you.......
Reed in Richmond, VA.
Tuesday, January 2, 2018 10:20:30 AM EST
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Beyond the obvious "possibly defective batteries", what could cause this is a partial short on the logic board. This could be caused by a defective subsystem, perhaps a camera or sensor, that is draining too much current from the battery. This could also be caused by an issue on the logic board itself that has the same effect on current draw.
One way to troubleshoot this is to disconnect as many peripherals as possible to see if this still occurs. You could disconnect cameras and sensor and then test the device. If the phone behaves the same way with all peripherals disconnected, then it could be the screen or a logic board issue.
Ultimately, if everything points to the logic board, then it will require more in depth troubleshooting by a micro-solderer. However, I doubt it's economically viable for an iPhone 4/4S.
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
Many thanks for taking the time. I failed to mention that the phone will turn off and stay turned off if the charger is connected. Many answers I've read mention theirs does that too.
Maybe I will disconnect some peripherals as you suggested and see if I get lucky with a discovery. I agree it's probably not economically viable to get far into a repair. Frankly, I just don't like an otherwise perfectly working phone to have a problem like this which if it had a simple fix could be enjoyed by somebody.
If I'm able to discover and fix the problem, I'll let you know what I found.
Thanks,
Reed.
von
I would recommend not repairing a phone that old. If you are in desperate need of a new phone you could even get a 5s. This repair would probably cost more than the phone itself.
Bewertung 0
Antwort hinzufügen
RWilliams wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 55
