Zum Hauptinhalt wechseln
Flash unit for use with Nikon Cameras
12 Fragen Alle anzeigen
My flash does not fire, even though it turns on and shows ready
I have a SB600 with new batteries and am using it with Nikon D300s. The flash turns on, shows ready but does not fire. I have tried turning it on/off, turned camera on/off. It just fails to fire.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
3 Kommentare
Any chance you dropped it or the old batteries "leaked"?
von
Thanks! No, I never keep batteries inside. And I did not drop it. The test fire button does not work.
von
Have you tried another flash on the camera, just to rule out the hot shoe? Also it is possible that the actual bulb has burned out.
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
try pressing the test fire button or shorting the terminals and it should flash (while not connected to your camera). If it does, then you know your flash works, if not try looking into your camera settings.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
SM123 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 27
Insgesamt: 3,310
