Zum Hauptinhalt wechseln
Repair guides and support for the laptop line of Acer's Aspire series for casual home and business use.
1191 Fragen Alle anzeigen
Hard disc drive replacement not SSD.
Hello everybody,
My Aspire One 110 laptop's SSD has crashed and I'm looking for a valid replacement.
All topics I've found browsing are a couple of years old and I'm not sure about witch or where buy a new one, that I can use with this tutorial .
Thanks.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung -1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
It looks like it uses a standard 9mm 2.5" laptop drive such as this: 750 GB 7200 RPM Seagate SATA Hard Drive (New)[verlinktes Produkt fehlt oder ist deaktiviert: IF107-099]
War diese Antwort hilfreich?
Bewertung 2
4 Kommentare:
looks like the 110 does use a standard hard drive: http://www.sparepartswarehouse.com/Acer,...
von
Hi again Mayer,
I have a 110 model.
Does it changes the guide steps a lot of?
Thanks.
von
Thanks for your answer, mayer,
just one little question. Does the hd has a zip connector? I've read in many places that I need this connexion for my laptop.
I liked this HS 320GB because is not my main computer.
Thanks for you time and best regards.
von
You have actually given two machines, your link is to a D150 the guide is to a 110. I gave an answer for the D150. What do you have?
von
Antwort hinzufügen
pdeandres35 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 3
Letzte 30 Tage: 3
Insgesamt: 3,080
