Zum Hauptinhalt wechseln
2,2 GHz (Turbo Boost bis zu 3,4 GHz), 2,5 GHz (Turbo Boost bis zu 3,7 GHz) oder 2,8 GHz (Turbo Boost bis zu 4,0 GHz) quad-core Intel Core i7 Prozessor mit 6 MB geteiltem L3 Cache.
774 Fragen Alle anzeigen
New battery seems poor quality
I just bought a new ifixit battery for may macbook and installed it accoring to the ifixit manual. When starting up after the install everything seems ok, but the new battery drains quickly. When using a batterytool (coconut battery) I saw that the design capacity is only 26% (see attached image). I assume this is not normal. What should I do to to get this fixed?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Rob, it appears you received a faulty battery. This can happen from time to time so just give a call to the ifixit team and I'm sure they'll help you out. Or you can send them an email but phone calls tend to get you a replacement in a more timely manner.
Phone support: http://help.ifixit.com/article/135-conta...
Email Support: http://help.ifixit.com/article/136-email...
War diese Antwort hilfreich?
Bewertung 1
3 Kommentare:
Did they ever replace the battery for you?
von
I personally do not order batteries from ifixit, but the method to follow would be to contact them for the replacement.
von
Yeah. I had to reset something (don't recall what it was), but after that reset everything was ok.
von
Antwort hinzufügen
Rob wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 4
Letzte 30 Tage: 5
Insgesamt: 346
