Whay does the code Ld mean on the display?
Whay does Ld code mean?
Ist dies eine gute Frage?
The Ld code indicates a blocked drain pump. Here's a video on how to fix it:
War diese Antwort hilfreich?
I have a Maytag Bravos MCT MVWB750WQ0. Hasn’t been run successfully since it was bought for $20 on Craigslist. Throwing an LD code. Took the Drain pump and all the hoses on the back off of the washer, and cleared them, there was a little bit of gunk but no blockage. Replaced the pump as it was very loud. Pulled the drum on the washer and pulled the plate over the drain hose inlet section and there was nothing there blocking it from draining. Put it back together, connected the hoses and turned the water on, plugged it in and the drain pump runs for 10 min before throwing an LD code, and it doesn’t do anything else. Any ideas would be Awesome. Thank You for Your time.
Richard - check the impeller. This video will indicate its location:
Hey, Just wanted to drop a quick thank you for the link to the video.
I have a maytag barvos an its throwing a f51code
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 58
Insgesamt: 10,750
