Recovering data with broken system
Windows 8.1 won't boot on this device. I have some important files to recover from it. Bootable usb with linux doesn't help. Is there a way to get them back?
Ist dies eine gute Frage?
You can try using an external USB adapter for the drive and then connect it to a working computer to try to copy your data.
War diese Antwort hilfreich?
does it have hdd though?
HDD or SSD? both should work fine with a hard drive docking station. You can find them on amazon I'm sure, or just open up your desktop and connect with sata.
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 12
Insgesamt: 429
6 Kommentare
Do you have a working desktop PC? So you could test the disk.
von ULEES
i have but im not sure if it has internal hdd
von Tomasz Kowalski
How did it break? did you drop it? spill something on it?
von Aiden
i installed updates and the system crashed
von Tomasz Kowalski
Problem fixed: i booted the windows 8.1 usb drive, then launched cmd. Using it I managed to move all the files to the usb. However switching between the drives doesn't work without "cd /d c:\".
von Tomasz Kowalski
1 weiteren Kommentar anzeigen
