iPod is disabled connect to itunes
someone tried to use my ipod and I had it locked, and now it's disabled and says to connect to iTunes
Ist dies eine gute Frage?
You could try to restore your iPod, just know that a restore will erase all your data. So make sure you have it backed up. Follow the instruction from Apple on here http://support.apple.com/kb/HT1339?viewl... Good Luck and let us know if it worked
War diese Antwort hilfreich?
Put your ipod into DFU mode by holding the Power key and the Home button at the same time for aproximately 8 seconds. After a good 8 second count release the power key but keep the home button pressed. Hold the home key down for about another 10 seconds. This can be done whether it is or is not connected to itunes. Youll know you are in DFU mode when you connect it to itunes and it is recognized as being in a recovery mode, the ipod should also have no display at that time. At that point try doing a restore.
now my ipod won't turn on. what do I do?
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 5
Insgesamt: 6,635
1 Kommentar
Otjya, did you plug it in? What happens? What operating system does your computer have? Windows or Mac?
von oldturkey03
