screen out of adjustment
touch screen to lcd screen out of adjustment hit the screen where you should and its out by about 20mm from left to right
Ist dies eine gute Frage?
Before you all go fiddling with complicated calibration settings, try this simple solution with an old toothbrush:
Use a card or fingernail to slightly lift the screen bezel around the touch screen, only needs to be just enough to get a few toothbrush bristles under it.
Work the brush bristles gradually right around the screen and note what drops out on a clean sheet of paper. A few grains of sand / grit is enough to screw up your screen sensitivity.
Better yet, blast air under the bezel as you lift it. Use a can of air (as used for cleaning photographic lenses) with a fine nozzle attached.
if this does not work
this is a link to a document which shows how to calibrate the tomtom screen for a certain model.
English:
http://www.martin-kolinsky.com/freeinstr...
and if this does not work...
First create a backup of your gps with windows explorer using the procedures in this link.This is important in protecting your map data which if you lose you may have to purchase a new map.
http://www.tomtomforums.com/general-tomt... target="_blank
To reset you gps hold the power button down for about 20 sec until you hear a drum beat then release the button.
To get the gps talking to your computer when you don't get the "connect to computer?" screen just plug the gps into the computer and reset the gps. It will connect to your computer when it resets.
To reinstall the application software use the procedure in this link.
if none of this helps then it is most likely a hardware fault
War diese Antwort hilfreich?
Thank you
Yes cleaned screen got a bit better then calibrated and is all fixed now I don't have to get rid of it
I can now use it cheers
Letzte 24 Stunden: 2
Letzte 7 Tage: 7
Letzte 30 Tage: 26
Insgesamt: 1,319
