Zum Hauptinhalt wechseln
Erste iPad Generation mit 3G, verfügbar mit 16, 32 oder 64 GB Speicherkapazität. Modell Nummer A1337. Reparaturen sind unkompliziert und verlangen keine Wärmezufuhr.
71 Fragen Alle anzeigen
Transfer 3G Antenna To New Glass
First I am not sure I am referring to this antenna correctly. On step 18 on this page it refers to this antenna as the GPS antenna:
iPad 3G Front Panel Assembly Replacement
but on step 7 on this page:
iPad 3G Teardown
it sounds like it is referred to as the 3G antenna. Regardless I am trying to transfer the antenna pictured in step 7 on this page:
iPad 3G Teardown
I can get the antenna out from between the glass and the frame but without using a heat gun I see no way of getting the antenna back in the new glass (no mine did not come with the antenna, and no I did not get it at ifixit). I have tried placing the antenna in place but I get VERY poor 3G. I looks and sounds like this is do to how the antenna is supposed to use the frame as an antenna.
Does anybody have any experience with transferring the Apple antenna to a new frame that does already have an antenna?
Thanks.
iPad 3G Bild
Anleitung
iPad 3G Teardown
Schwierigkeitsgrad:
Mittel
iPad 3G Front Panel Assembly Bild
Anleitung
Schwierigkeitsgrad:
Schwierig
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung -1
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
andyboutte,
Yeah, that antennae is quite difficult. Unfortunately, it seems that the best way is to loosen the adhesive using a heat gun in order to preserve what seems to be some sort of NASA grade adhesive :)
It takes a lot of time and patience, so hang in there. And be careful with the heat gun. If you have it set too high or too close to your work area, you can accidently melt the plastic gasket attached to the digitizer glass. I usually leave mine at about 500 degrees.
War diese Antwort hilfreich?
Bewertung 0
Ok, it is a tough one. Because me digitizer was bad, I sacraficed it and pryed the antenna out. The glue is like alien snot. This worked fast and the digitizer was being thrown away anyway. Cheers.
Bewertung 0
Antwort hinzufügen
andyboutte wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 4
Insgesamt: 2,097
