Zum Hauptinhalt wechseln
iPod Classic der 6. Generation. Modell A1238 / 80, 120 oder 160 GB Festplatte / schwarze oder silberne Vorderseite aus Metall
Dead iPod- NOT the battery
iPod won't turn on, regardless of whether or not it is plugged into anything. The battery life is still in really good shape and was fully charged at the time it stopped working. Had walked to work with it on, left it in pocket, took off coat, then took out iPod to use in an audio system and it wouldn't turn on. Seems improbable it could randomly die in 5 minutes...
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 14
4 Kommentare
It worked, oldturkey. Thank you for protecting me from my own karma.
von
Thank you for accepting my answer. Wishing you the best of luck and keep on jamming:-)
von
Thank You It worked never thought of the on off button i tried everything else
Thanks Again
von
Your instructions worked miraculously! I really thought I had lost it (and all my recordings) forever. THANK YOU!
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Yes, they can die from one minute to the next :-) Try to reset your iPod
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
Press and hold the Menu and Select buttons until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step. If this doesn’t work, you should try plugging your iPod into a power source and let it charge. Then repeat the steps.
What happens when you plug it into your computer? If this does not work, you may have to take a closer look at it. Let us know how it is going. Good Luck
War diese Antwort hilfreich?
Bewertung 20
32 Kommentare:
Had same problem. Solution worked. Thank you very much.
von
awesome...problem solved...thanks
von
Nice. Thank you. Problem solved!
von
Thanks so much! worked perfectly
von
@Matt Tierney, you are welcome :)
von
27 weitere Kommentare anzeigen
will I lose my tunes if I replace a dead hard drive on my apple iPod 5th generation
Bewertung 0
1 Kommentar:
Yea as this is where the "Tunes" are kept.
von
Antwort hinzufügen
Danielle wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 12
Letzte 30 Tage: 55
Insgesamt: 50,101
