Zum Hauptinhalt wechseln
Das iPhone 6 mit dem 4,7 Zoll Display ist die kleinere Version des iPhone 6 Plus und kam am 19. September 2014 auf dem Markt. Es hat die Modelnnummern A1549, A1586 und A1589.
4994 Fragen Alle anzeigen
iPhone screen not working
I replaced iPhone 6 screen a few days ago , as I have done it many times before , there was no problem until the battery had to be replaced today , as I put the screen back on I notice it has lines going up and down the phone and looks as though it had been dropped even though I didn’t drop it and I was very careful taking the screen off and putting it back on , any reasons why ? Is it the screen or the motorboard itself , thank you
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Either it's the flex cable on the screen gone bad or not connected properly to the logic board.
If the screen connectors on the logic board seem fine and you already tried replugging the screen then the screen is faulty.
War diese Antwort hilfreich?
Bewertung 3
3 Kommentare:
Thank you so much
von
One of the connectors don’t click like the rest , does this matter?
von
The two horizontal ones from the screen should click in normally.
There is another cable that clicks in furthest away from the rear camera and that is for the front camera you don't need to worry about that one.
The one cable that is horizontal and smallest is for the LCD screen display.
von
Antwort hinzufügen
Mary sue wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 44
