Zum Hauptinhalt wechseln
This is the first generation of the Ford Escape, a compact crossover SUV. Production started in 2000 for the 2001 model year.
Front and Rear Windshield Washers Not Working
The windshield washer fluid will not come out in neither the front or the rear. I checked the fuses and they are both fine. Any thoughts on what it could be? I watched a video on replacing the pumps and they mention there is a pump for each window so I'm not sure how likely it is for both pumps to go out at the same time. Thank you
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar:
Same problem here. Were you able to find a solution?
von
Einen Kommentar hinzufügen
1 Antwort
I had to change both. There on the left side by the front wheel. I went to Ford to replace them.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Lucia Munoz wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 19
Insgesamt: 2,005
