Zum Hauptinhalt wechseln
Released in 2011, the Asus K53SV is a 15.6-inch laptop with a 2nd-generation Intel processor and a dedicated Nvidia graphics card.
5 Fragen Alle anzeigen
How to Adding second HDD to a Asus K53SD laptop?
my Laptop is Asus K53SD
how to Adding second HDD and Ram to a Asus K53SD laptop?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Hi,
Here is a video which shows how to replace the HDD with a SSD and re-install the HDD using a caddy in the DVD drive bay in an Asus K53SD laptop.
The video commentary is in Russian but the video is self explanatory.
Looking at the video it appears that the RAM slots are next to the HDD (shown near the beginning of the video during the removal/insertion of the HDD/SSD).
The specifications for the laptop state that it has two ( 2) SO-DIMM sockets for memory handling up to a total of 8GB SDRAM - DDR3 1333 MHz.
Hopefully this is of some help
War diese Antwort hilfreich?
Bewertung 3
2 Kommentare:
my labtop is: Asus K53SD laptop.
i buy SSD Hard: Samsung 860 Evo SSD Drive 250GB
Which CADDY model should I buy?
von
Hi @ Global Ninety,
Just search online for Asus K53SD caddy to get results.
Here's a link to just one supplier to give an idea of the price of the part.
There are plenty of other suppliers that may suit you better.
von
Hi Global Ninety, you will need to get SATA Hard Drive Caddy Case.
In this case, the CD / DVD drive would be used for secondary hdd, Do note on the mm on the drive caddy in order to fit onto your laptop properly.
Bewertung 1
Antwort hinzufügen
Global Ninety wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 10
Insgesamt: 2,892
