Zum Hauptinhalt wechseln
The Samsung Chromebook 3, introduced in 2016, is the successor to the Chromebook 2 and features an Intel Celeron N3060 processor. The XE500C13-K01US model has 2 GB RAM while the XE500C13-K02US model has 4 GB RAM.
17 Fragen Alle anzeigen
Why is my Chromebook charging light flashing blue?
My school's Chromebook has a flashing blue light. Samsung support was not very helpful and just said to leave it charged and see if it powers on. Does anyone else have a solution for this question.
Ist dies eine gute Frage?
Bewertung 6
1 Kommentar
My samsung chrome computer blue lightblinking how do you fix this?
von
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
If you can, remove the battery from the laptop and hold the power button for 30 seconds. Then try running the computer w/o the battery. If this works, give it a minute to go through the bootup process, and see if the light is still flashing. If the light is flashing, then it probably is the dead motherboard, or maybe power regulation. If the light is normal, just put your battery back in and see if it works, without the charger. If it is good, drain your battery, (I know, it's not recommended, just do it :D) and then once your battery is drained, plug in, with the LID CLOSED, and the COMPUTER OFF, and let it charge until the light turns green, signaling that the laptop is done.
War diese Antwort hilfreich?
Bewertung 6
4 Kommentare:
Dude Sam, thank you so much!!!!!
von
@Scott Georgson no problem! Glad it worked :D
von
You might not be able to do that. You have to ask your school 1st.
von
thank you Sam you just saved me over 500$
von
Sometimes you just need to restart your Chromebook.
Bewertung 0
Antwort hinzufügen
Cuthbert Thomas wird auf ewig dankbar sein.
Seitenaufrufe:
Letzten 24 Stunden: 3
Letzten 7 Tage: 21
Letzten 30 Tage: 132
Insgesamt: 17,063
