Hi @be7o ,
Do you get stereo audio when using the earphones?
Go to Apps > Settings > Accessibility > Hearing > Left / right sound balance and check that the slider control is positioned for equal stereo sound.
You may also wish to check that the Apps > Settings > Accessibility > Hearing > Mono Audio setting is not enabled.
Hi @be7o ,
I'm thinking that you either have a faulty speaker or a faulty speaker connection.
Here is a link to a video that shows how to dis-assemble the tablet.
At 4:52 minutes into the video it shows how to disconnect the battery from the systemboard.
The basic rule in electronics repair to prevent more problems when repairing is : power off first, on last
(There is still power on the systemboard even though the tablet is turned off so removing the power source, in this case the battery is advisable. The battery only has to be disconnected, not physically removed.)
At 6:19 minutes into the video the left speaker is shown being disconnected.
Here is a link to suppliers of the replacement part.
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
3
Abbrechen
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
