Zum Hauptinhalt wechseln
iPad Air Wi-Fi + Cellular, Modellnummer A1475. Verfügbar in Space Gray oder Silber, Speicheroptionen 16/32/64/128 GB.
USB device not recognised. Win 7 home premium.
I have an Ipad air LTE. was produced to me as DISABLED as they put the wrong password in too many times. The ipad charges through the port but is not recognised by windows so i can't do much to get into the device. Tried on several machines so it isn't computer related. Have not got another lead to try, but my ipad mini works fine connected to same computers, same lead. Any suggestions?
Sounds like an electronics repair job i *think*. Thoughts?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
5 Kommentare
Have you installed iTunes? Have you tried different cables?
von
Yes i have, latest version and no i havn't. The mini works so it's not the cable
von
Cheers mate, yes it goes into recovery mode but as soon as it is plugged into the pc the USB message comes up saying it can't recognize the device, so that's where the world ends lol
von
@smythie17 Hello, does anything show up on iTunes when you plug it in?
von
no it does not
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Hi @smythie17 ,
Try forcing the iPad into the recovery mode and see if this works at all.
1. Turn off the iPad
2. Launch iTunes.
3. Plug the USB cable into the computer.
4. Press and hold the Home button down and plug the other end of the USB cable into the docking port.
Do not release the Home button until you see the picture of iTunes and plug
5. Release the Home button.
6. Hopefully iTunes has detected that the iPad is in the recovery mode.
7. Select Restore iPad
War diese Antwort hilfreich?
Bewertung 2
Go into Device Manager
See if you have any devices with error messages
Remove these from Device Manager
then scan for hardware changes.
Bewertung 0
1 Kommentar:
Did that as well, just comes up with same error message when connected
von
Antwort hinzufügen
Gary wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 15
Insgesamt: 875
