Zum Hauptinhalt wechseln
2.0GHz, 2.3GHz, oder 2.6GHz quad-core Intel Core i7 Prozessor (mit Turbo Boost bis zu 3,8GHz) mit 6MB geteiltem L3 Cache.
580 Fragen Alle anzeigen
Screen problem after battery replacement
I'm currently using Macbook Pro Retina 15" Late 2013.
I just replaced the battery that I ordered from this site. Followed every step in the tutorial. When I turn the laptop on, the screen acts weird as you can see from this link.
https://youtu.be/9ANT4xCj87A
Everything else such as keyboard, speaker, trackpad is working fine.
How to fix this ?
Thank you.
Ist dies eine gute Frage?
Bewertung 2
1 Kommentar:
I have a 13" Late 2013 MacBook Pro that seems to be starting to do this same thing. I did replace the battery a few months ago.
von
Einen Kommentar hinzufügen
1 Antwort
Are you sure its the 2013 model and not 2012? the 2012 had an issue with the gpu vcore chip and poor solder joints, the solution is to go around the edge with alot of no clean flux and a really good fine tip soldering iron and resolder each joint.
Apple used a pathetic piece of shoe rubber between the bottom casing and the board to hold it in place as a ‘fix’ in there repair centres and its well documented that fails in time, apple never revised the board so its likely to have caused issues just removing the bottom case and disturbing that chip.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Thanyaboon Tovorapan wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 4
Insgesamt: 170
