Zum Hauptinhalt wechseln
Der Mac Pro (Anfang 2009) kam im März 2009 auf den Markt. Er führte erstmals die Nehalem Architektur von Intel in die professionelle Apple Desktop Reihe ein, und verfügt über ein leicht neu konzipiertes Inneres, das auch bei den 2010 und 2012 CPU Updates beibehalten wurde.
199 Fragen Alle anzeigen
2009 updating to High Sierra
Hello, I'm considering upgrade of my 4,1 Mac Pro (upgraded and flashed to 5.1) but I'm not sure if my GTX 970 will be still working after upgrade. That is the only reason I didn't upgraded it yet.
I don't have an original GPU. What do you recommend doing in that situation?
Thanks in advance for any help
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare
Have you flashed it yet, if so why method did you use?
von
be carefull of MAX 300W on ALL PCIe slots
von
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Hello Maciek,
I have the same Mac Pro, only with a GTX 1060. From what i saw, there are macOS Cuda drivers for macOS 10.13.x ( http://www.nvidia.com/object/macosx-cuda... ) and the drivers for the Quadro and Geforce GPU's ( http://www.nvidia.com/download/driverRes... ). So practically, yes you can install the new macOS High Sierra. The only problem is that when you upgrade it, I don't think that the GPU is going to work until you install the drivers, so it's "safer" for you to do it with a stock GPU. It might work, but I'm not totally sure, because I never tried to do it.
War diese Antwort hilfreich?
Bewertung 2
3 Kommentare:
Have you actually done this upgrade on your machine?
von
No, I have not.
von
Just an update. I have done the upgrade from Sierra to High Sierra and it work good. The only problem is that you need the old GPU to be able to fully update it, because you need to install the new drivers and to go through the initial setup after the upgrade.
von
Hi. You can pick up the default nvidia Gfx GT120 on ebay for super cheap these days. I keep one handy just in case I need to get to the pre-boot screen. There are better cards that support pre-boot and even Metal, but this one is super handy for slapping in when I just need video to boot because of some other issue. Even Mojave will boot with this graphics card provided you installed it with a metal supported one at the time.
Not a full answer but a tip for sure.
Bewertung 0
Antwort hinzufügen
Maciek Welk wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 4
Insgesamt: 1,749
