Zum Hauptinhalt wechseln
Dritte iPad Generation, 4G fähig, Modellnummer A1430, erhältlich seit dem 16. März 2012. Die Reparatur erfordert Hitzezufuhr und vorsichtiges Hebeln.
106 Fragen Alle anzeigen
After battery replacement IPAD restarts every 2-3min
Hello,
After I replaced battery on my IPAD 3 (4G), currently I experience issue with it since it restarts itself every 2-3min.
I read the other forum topics and understood that the problem might be due to a fake battery but I bought another battery and tried with it. Unfortunately the results was the same - IPAD restarts in every 2-3min.
In general, when the IPAD is switched on, it searches for mobile network, while it is connected to WI-FI and after it can not find any network, it restarts. This trend is based on my observation and it does not matter if there is SIM card inserted or not.
My concern is related that the IPAD can not detect the 4G module correctly, it is connected to the mother board but still it is strange.
Would you please be able to suggest any solutions for this issue? It will be very helpful because at the moment, it is useless like that.
Thank you.
Update (02/05/2018)
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
A bad battery is the typical issue for these kinds of symptoms. However, after trying two different batteries, it may not be the case here. To know for certain, measure the voltage of the battery directly (while removed from the iPad) with a multimeter. If you are measuring more than 3.5V, the the device should boot fine.
If the voltage looks good, then you may have damaged something when you disassembled the iPad. Check the logic board in the connector area and inspect the flex cables for tears, even tiny ones.
War diese Antwort hilfreich?
Bewertung 4
1 Kommentar:
Hello Minho,
Thank you for your quick advice. However, I checked the batteries and they look good in terms of voltage.
In regards to connections, I feel confident in all of them apart from the 4G to the logic board connection which I believe might be the issue. The connection there is tiny. I think that this might be the issue since it the ipad is searching for a network but can not find it and it restarts. Please find photos below:
Do you have any idea what I can do in this case>
von
battrey is bad change new one
Bewertung 0
1 Kommentar:
Edy Jolin read the question. the OP already tried 2 new batteries. Any other ideas?
von
if possible do a factory reset via itunes on your computer. while typically this would be caused by a bad battery or such, I have seen software issues do weird things before, especially on iOS devices
Bewertung 0
2 Kommentare:
I did a factory reset on mine and it's still doing it, any other suggestions?
von
@Torrie Wiegmann what are the exact issues with your iPad and what model is your iPad? Looks like nobody has checked back on this question for about 2 yeas so you may not get any help on this one.
von
Antwort hinzufügen
Paul wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 10
Letzte 30 Tage: 21
Insgesamt: 2,631
