Zum Hauptinhalt wechseln
Das iPhone 6 mit dem 4,7 Zoll Display ist die kleinere Version des iPhone 6 Plus und kam am 19. September 2014 auf dem Markt. Es hat die Modelnnummern A1549, A1586 und A1589.
4994 Fragen Alle anzeigen
Red Vertical lines and a black bar.
So recently my iPhone 6 fell approximately 8 inches from my knee on a gym floor, and when I picked it up it had blue lines running vertically on the screen, and the lines only seem to appear wherever bright lights on the screen are. Later, a large black bar ran up the right side of my screen that is about an inch thick. I can still tap apps and things behind the black line but I cannot see them. All of this happened yesterday, and just recently the blue lines have turned a redish pink color. I imagine I probably just have to replace the screen, but does it sound like there is anything crazy bad about my phone? Thank you in advance!
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar
hi!
i have this problem too... but for now can you visit and share http://fifamobilehack.today/
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
I think your "iPhone 6" will be repaired by repairing the screen. If you can still operate it, you'd better back up your data as soon as possible. You may not be able to operate it a little more!
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
Thank you so much! I will do this for sure!!!
von
I have the red/blue vertical lines, but it all started after I had my screen replaced.
Everything is backed up. Restore didn’t work.
Seeing Apple on Wed.
Bewertung 0
Antwort hinzufügen
Hunter West wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 3,620
