Zum Hauptinhalt wechseln
Der JBL Charge 3 ist an seiner unverwechselbaren gewebten Lautsprecherabdeckung und seinen Gummidetails zu erkennen. Er kam 2016 auf den auf den Markt und verfügt über ein vollständig wasserfestes Design, 20 Stunden Wiedergabezeit und Bluetooth Konnektivität.
90 Fragen Alle anzeigen
Battery indicators always lit
Hello, recently I got JBL Charge 3 bluetooth speaker. Everything is fine except one thing. Battery indicators are always on. All 5 of them. Even in the JBL Connect there's always full bar. I was using it all day and when I came home I charged it. When I put it to electricity only 2 leds were lit and third was blinking. After some minutes all 4 leds were lit and 5th was blinking. The 5th led is blinking endlessly.. Everything works fine except the indicators... I will try to completely drain its battery and recharge it and I'll also try resetting it(power button and volume down). When I got it, it was charged to 4 leds and it was draining( only 3 leds left after some time). I put it to charge and I updated the firmware and leave it to charge. After some time the 5th led was still blinking endlessly but when I took off the charge cable it had 5 leds lit, those were still lit after 3-4 hours of usage...
Ist dies eine gute Frage?
Bewertung 2
1 Kommentar:
Received my NEW JBL Charge 3. When I initially plugged it in for its initial charge there were no status lights lit which tells me the battery arrived with a totally dead battery and it may have expired on the shelf.
The speaker was ordered 25 Nov, Order# 114-0467390-0395426. I’ll bet the battery is new and bad on the shelf. Please inform me on complete replacement of a new battery and replacement instructions. Thank you Bill Martin, Luverne MN
von
Einen Kommentar hinzufügen
3 Antworten
Hello. I had the same problem with a JBL Pulse 3.
I even went to the store where I bought it to replace it (which was kindly done by the salesperson) because I read somewhere the problem was a battery problem.
I charged the "new" unit with the same "defect", but..
But I solved it simply by upgrading the firmware, done through my cell phone.
That was it. No more 5th led blinking eternally.
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
How to upgrade the firmware?
von
I already updated the firmware. Nothing was wrong with it.. The 5th led just takes too long to charge.. The first 4 leds take about 20 min each, but the third one takes around 2-3 hours. I thought it has defect because I used it for like 2 hours and it still had 5 leds on. When I charged it suddenly had just 3. But now it work fine. Thanks for the answer though. :)
Bewertung 0
1 Kommentar:
von
my jbl charge 3 is charging for over 4 hours and its still on the 1st led.
what do i do??
Bewertung 0
1 Kommentar:
Get a better charger.
von
Antwort hinzufügen
Josef wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 16
Letzte 30 Tage: 57
Insgesamt: 16,502
